Det här kan man ju fundera över:
The WarZone skrev:While we raised the possibility in our story at the time that one of Ukraine’s donated air defense systems could have been involved in downing those aircraft, we also noted that such a move inside Russian territory could jeopardize future arms supplies. U.S. and allied officials have repeatedly said that such arms are only meant for use inside Ukrainian territory.
Shortly after the aircraft were downed, speculation floated about the possibility that a Patriot system might have been involved.
It is unclear why Ukraine waited until now to indicate that a Patriot battery might have been used, if Kyiv has any concern that such a use might cause consternation of allies or if this is just another information operation.
I varje fall har Olaf Scholz nyligen sagt att det t.v. inte är aktuellt att donera den tysk-svenska kryssningsmissilen KEPD-350 Taurus till Ukraina (tysk språkövning)
The WarZone skrev:While Shoigu proclaimed his claimed Storm Shadow kills, German Chancellor Olaf Scholz on Sunday said he did not want to provide Ukraine with the air-launched, conventionally armed Taurus KEPD 350 cruise missile out of concern that Kyiv would use them on Russian territory.
“We carefully check all the requests we receive," Scholz told German ARD TV. "But for us there is a principle that I share with the U.S. president – we do not want the weapons we supply to be used to attack Russian territories."
KEPD-350 Taurus skrev jag om här: viewtopic.php?p=413868#p413868
dr Cassandra Nojdh skrev: måndag 27 mars 2023 11:15 Man ska inte fästa för stort avseende vid ett twitter-rykte som refererar till ett propagandauttalande från den kinesiska kommunistdiktaturen.
China’s J-20 Fighter With Long-Awaited WS-15 Engines May Have Flown
The War Zone skrev:There are signs that a Chinese J-20 stealth fighter has flown for the first time with two new indigenously developed WS-15 jet engines installed. If true, this would be a significant milestone in the continued development of the J-20 design and the WS-15 turbofan.
The quality of the imagery makes it difficult to independently determine conclusively if the J-20 in question indeed has WS-15s in place of the WS-10-series turbofans that now generally power these jets. The original J-20 prototypes and initial production examples were powered by Russian-made AL-31 turbofans. The easiest way to tell for sure that the reportedly re-engined J-20 has WS-15s would be to get a close look at the exhaust nozzles.
Med största sannolikhet stämmer ryktet. Således har Kina kommit ikapp Ryssland i utvecklingen av turbofläktmotorer.
Xi Jinping warned Vladimir Putin against nuclear attack in Ukraine
Financial Times skrev:Xi Jinping personally warned Vladimir Putin against using nuclear weapons in Ukraine, indicating Beijing harbours concerns about Russia’s war even as it offers tacit backing to Moscow, according to western and Chinese officials.
People close to the Kremlin say the Russian leader independently decided that tactical nuclear weapons would not give Russia an advantage after projecting scenarios resulting from their use. A nuclear strike was likely to turn areas that Putin has claimed for Russia into an irradiated wasteland while doing little to help his forces advance, the people said.
Kyiv has meanwhile expressed concern that Russia could instead cause an accident at the Zaporizhzhia nuclear plant — the largest in Europe, which Russian forces have occupied since March 2022 — and deny responsibility.
Kinas president Xi Jinping varnade personligen Rysslands president Vladimir Putin för att använda kärnvapen under kriget i Ukraina. Kinesiska tjänstemän tar åt sig äran för att ha övertygat Putin om att backa från sina hot om att använda kärnvapen. Däremot eskalerar retoriken om att Zaporizjzja sprängs...
Russia has lost half its combat capability in Ukraine, says UK armed forces chief
Financial Times skrev:Admiral Sir Tony Radakin rejected suggestions that Ukraine’s counter-offensive was proceeding slowly, arguing that the pushback against Russia was “never a singular act”, and that Kyiv’s military strategy to “starve, stretch and strike” was gradually breaking down Russian defensive lines.
Radakin acknowledged that the “stronger than expected” density of Russian minefields, a lack of Ukrainian air cover and “not all the [military] equipment that they [Kyiv] desired” had complicated the campaign.
“Russia has lost nearly half the combat effectiveness of its army,” Radakin said. “Last year it fired 10mn artillery shells but at best can produce 1mn shells a year. It has lost 2,500 tanks and at best can produce 200 [new] tanks a year,” he said.
Mycket tyder på att Ryssland har ammunitionsbrist, eller "shell diet". Jämför tidigare uttalanden av militäranalytikerna Kofman och Karl.
Russian Army began using modernized 155mm Krasnopol-M2 projectiles
BulgarianMilitary.com skrev:The Krasnopol-M2 155mm round is primarily used by the Russian military in their artillery systems. Specifically, it is designed to be fired from the 2S19 Msta-S self-propelled howitzer and the 2S35 Koalitsiya-SV, a newer self-propelled artillery system. These systems are used for long-range artillery support and can be deployed in a variety of combat scenarios.
However, it is important to note that the Krasnopol-M2 round is not limited to use in Russian weapon systems. It is a precision-guided ammunition that can be fired from any artillery system capable of firing 155mm rounds. This means that it could potentially be used in other countries artillery systems as well, assuming they have access to the ammunition.
Är inte detta fel kaliber!?
Enceladus skrev: onsdag 05 juli 2023 14:22
OK. Då tittar vi på vad som faktiskt skrevs i mars; viewtopic.php?p=412650#p412650
Enceladus skrev: söndag 26 mars 2023 23:34 Samtidigt börjar Kina massproducera turbofläktmotorn WS-15 som framtida versioner av smygflygplanet Chengdu J-20 är tänkta att använda. Dessa två permanenta medlemmar i FN:s säkerhetsråd är på intet sätt jämbördiga.
Xian WS-15 kan eventuellt se ut såhär
Det var alltså massproduktionen det handlar om. The WarZone manar till en viss försiktighet, eftersom kommunistdiktaturen är en fena på propaganda:
All told, while it remains to be conclusively confirmed, the first flight of a J-20 with a pair of WS-15 engines would be a major, long-awaited, step forward for the Chinese military and the country's aviation industry.
Men kineserna jobbar på detta, helt klart.
Senast redigerad av dr Cassandra Nojdh den onsdag 05 juli 2023 17:05, redigerad totalt 1 gånger.
Enceladus skrev: onsdag 05 juli 2023 14:22 Russian Army began using modernized 155mm Krasnopol-M2 projectiles
Krasnopol-M2 155mm är den senaste utförandet på exportversionen av granaten (om denna version finns även för kaliber 152mm - sovjetisk/rysk standard - är okänt). Ryssarna har även artillerisystem med 155mm kaliber, som ex.vis denna: 2S19M1 MSTA-S 155mm Self-Propelled Howitzer. Hur mycket 155mm-artilleri Ryssland har till sitt förfogande förbandssatt är förstås okänt. De kanske rent av vill gå över till Nato-standard :D
Det här är en ganska kraftigt upphottad version av den gamla Krasnopol-granaten, en sovjetisk motsvarighet till USA:s M712 Copperhead, en av de första precisionsstyrda granaterna. Copperheads skottvidd är ganska modest, 16 km, och Krasnolpol nådde inte mycket längre, 20 km. Krasnopol-M2 påstås nå 25 km.
Till skillnad från amerikanska Excalibur och PGK är det inte en fire-and-forget-granat, utan den har en semi-aktiv lasermålsökare. Det innebär att "någon" måste ha fri sikt till och belysa målet med en laserpekare. Det kan vara framskjutna eldledarpositioner, möjligen kan man också tänka sig UAV-burna laserpekare, ungefär som Azerbajan använde den turkiska bomben QFAB-250 LG mot Armenien. Inte så påfallande imponerande alltså, laserstyrningen har dock den fördelen att den under gynnsamma förhållanden gör det möjligt att bekämpa rörliga mål.
Boyko Nikolov (mer om denne Nikolov nedan) i BulgarianMilitary höjer förstås granaten till skyarna:
BulgarianMilitary/Boyko Nikolov skrev:The Krasnopol-M2 is considered to be one of the most advanced artillery shells in the world and is widely used by the Russian military. Its precision and accuracy make it a highly effective weapon against a variety of targets.
The Krasnopol-M2 shell is designed to be used against a variety of targets, including armored vehicles, fortifications, and buildings. It is particularly effective against moving targets, such as tanks or other vehicles, as it can track and follow them as they move.
The damage caused by the Krasnopol-M2 shell depends on the type of target it hits. Against armored vehicles, it can penetrate the armor and cause significant damage to the vehicle and its crew. Against fortifications and buildings, it can create a hole or breach in the structure, allowing friendly forces to enter or providing a new line of sight for artillery fire.
Den som har behov av Krasnopol-granater vänder sig med förtroende till Rosoboronexport: http://roe.ru/eng/catalog/land-forces/g ... ems/km-1m/
OBS. Gäller ej Ukraina, som vidareutvecklat Krasnopol till en egen typ av granat, Kvitnik : https://militaryleak.com/2022/04/02/ukr ... mmunition/
Senast redigerad av dr Cassandra Nojdh den onsdag 05 juli 2023 20:49, redigerad totalt 3 gång.
Ryssland skickar fler stridsvagnar från 1950-talet till fronten:
Dmitri skrev:A train transferring old Russian tanks was noticed in Voronezh - judging by the comments of the locals, even they realise what sort of old stuff Russia has to resort to.
Somliga skribenter har identifierat stridsvagnsmodellen T-54-3 från 1951. Kan detta vara Rysslands äldsta kvarvarande modell förutom T-34 från paraderna?
BulgarianMilitary, en sajt som inte har något med Bulgariens försvarsmakt att göra utan drivs av den här figuren, Boyko Nikolov har jag tidigare betraktat som en hyfsat pålitlig källa, men på senare tid tycker jag att den har börjat luta alltmer åt Ryssland och Putin, ungefär som de indiska putinisterna.
I flera artiklar hyllas de ryska helikopterstyrkorna I den sistnämnda referensen ovan framställs de ryska attackhelikoptrarna som praktiskt taget osårbara för fientligt luftvärn, genom sina överlägsna motmedel.
Dessutom skriver Nikolov om om kryssningsmissilen Storm Shadows bristande effektivitet, genom att det ryska luftvärnet har blivit så duktiga på att bekämpa denna: Storm Shadow ‘kill rate’ decreases, Russians ‘ended’ another one
Det intressanta är att artikeln är illustrerad bl.a. med en bild av den tysk-svenska KEPD-350 Taurus. Bättre var alltså inte faktakollen.
I fortsättningen kommer jag nog att betrakta BulgarianMilitary som (smyg)putinistisk och åberopa denna källa med försiktighet.
Frågan är egentligen var Bulgarien har sina sympatier, eftersom de gått under den sk. radarn på ett helt annat sätt än Ungern/Orbanistan.
Bulgaria’s Black Sea Dilemma: NATO Ally or Russian Gateway?
(OBS att detta skrevs före krigsutbrottet 2022).
Senast redigerad av dr Cassandra Nojdh den onsdag 05 juli 2023 17:23, redigerad totalt 1 gånger.
Den som vill studera BulgarianMilitarys putinism rekommenderas huvudsidan, för vidare fördjupning: https://bulgarianmilitary.com/
I den här artikeln om Storm Shadow: Russian air defense has shot down 10+ Storm Shadows and missed 6
åberopar Nikolov faktiskt uttryckligen den indiske putinisten Prakash Nandas EurAsian Times.
Putin-varning, alltså!
F.ö. ser jag att jag redan i februari uppmärksammade EurAsian Times hyllning av Krasnopol-granaten:
dr Cassandra Nojdh skrev: fredag 03 februari 2023 17:41 Det var en del snack om "neutrala indier" igårkväll. I avvaktan på amerikanska försvarsdepartementets presskonferens kl. 18 har jag sammanställt några vapentekniska notiser från en "neutral indier". Håll tillgodo:
Artillery That Acts Like A Missile! Russia Wields Its Maneuverable & Self-Homing Krasnopol That Can ‘Demolish’ Ukraine’s Tanks
UK to start training Ukrainian pilots in August
Ukrainska Pravda skrev:Heappey said that 20 Ukrainian pilots will start basic training in the UK in August.
Politico reported that Ukraine might start receiving F-16 fighter jets by early 2024.
Blir det inga västerländska stridsflygplan i år!?
Joe Biden blocked Ben Wallace from top Nato role after F-16 row
The Telegraph skrev:Mr Sunak vowed to build an “international coalition” to help procure F-16 aircraft for Ukraine after a meeting with Mark Rutte, his Dutch counterpart, in May.
After months of debate, in May, Mr Wallace said any plan involving the aircraft hinged on Washington, ramping up pressure on Mr Biden. Days later, the US president relented and agreed to let allies train Ukrainian pilots on F-16s and its array of weapon systems.
On Tuesday, The Telegraph reported that Mr Biden is lining up Ursula von der Leyen, the EU’s top official, to replace Mr Stoltenberg.
The report came as Mr Stoltenberg’s mandate was extended until October 2024, a similar time to when the former German defence minister’s term as the head of the European Commission ends.
USA ville uppenbarligen inte skicka amerikanska stridsflygplan till Ukraina, men trycket blev för stort. Däremot snuvades Wallace på rollen som Nato-chef.
Uppgifter: USA närmar sig försäljning av F16-plan till Turkiet
Sveriges Radio skrev:Inför Kristerssons möte med Biden kommer det uppgifter om att det rör på sig i frågan om att USA kan sälja F16-plan till Turkiet – något som skulle kunna göra president Erdogan mer benägen att godkänna Sverige som Natomedlem.
Flera källor uppger att intensiva förhandlingar pågår om att godkänna försäljning av amerikanska stridsflygplan till Turkiet. Blir Erdogan äntligen nöjd?
Ovanstående handlar inte om teknik utan om taktik. Det är inte den här trådens syfte. Var vänlig respektera detta och skriv sådana här inlägg - som handlar om krigsförloppet - i tråden "Inför ryssarnas invasion".
dr Cassandra Nojdh skrev: onsdag 05 juli 2023 22:32 Ovanstående handlar inte om teknik utan om taktik. Det är inte den här trådens syfte. Var vänlig respektera detta och skriv sådana här inlägg - som handlar om krigsförloppet - i tråden "Inför ryssarnas invasion".
Det är lätt hänt att ett inlägg hamnar i fel tråd. Skribenten har själv flyttat på några av sina inlägg, vilket jag också gjorde nyss!
Enceladus skrev: onsdag 05 juli 2023 22:48
Det är bra, det. Då håller vi koll på varandra! :D :D
dr Cassandra Nojdh skrev: fredag 30 juni 2023 18:09 Många ukrainare har dött och kommer tyvärr att dö även fortsättningsvis. Ingendera av ovan nämnda vapnen kommer dock att annat än marginellt påverka krigets förlopp eller utgång.
Ukraine wants American cluster bombs—quickly
The Economist skrev:Ben Hodges, a former commander of the US Army in Europe, says that cluster munitions could suppress Russian fire from trenches and artillery, giving Ukraine more time to clear a path through minefields, which are proving to be a serious problem. One formal study conducted recently by a NATO country suggests that in a division-sized operation to break through well-prepared complex defences, the use of cluster munitions could save around 1,000 Ukrainian lives, though officials concede that the figures are hazy.
Ukrainians retort that they are the ones best placed to judge the trade-off between firepower today and civilian harm on their territory tomorrow. They insist that they would carefully map where the munitions are used, abstain from firing them in urban areas and commit to a post-war de-mining programme. In any case, any taboo over using cluster bombs has already been broken: both Ukraine and Russia have already fired Soviet-era ones at scale, according to data collected by HRW, and Ukraine is also firing some supplied by Turkey. As of April, over 174,000 square kilometres of territory was contaminated with explosive objects.
Proponents also insist that the weapons are not as hazardous as they once were. Around 2.5% to 5% of the bomblets in America’s older DPICMs fail to explode, remaining a potential danger to civilians for years to come, says an American artillery expert. Officials claim the dud rate for newer ones is around 1.2%, though live-fire testing has cast doubt on that figure. The equivalent rate for the Soviet-type cluster munitions already scattered over Ukraine is probably an order of magnitude higher, says the expert, worsened by poor maintenance. “You’d be shocked at the level of corrosion and disrepair,” says the expert. Whatever America decides—it is thought to be leaning towards a delivery—Ukraine will be dealing with unexploded ordinance for decades to come.
Alla håller tydligen inte med om skribentens slutsatser. Enligt ovanstående studie skulle klusterammunition kunna rädda tusentals ukrainska liv.
Enceladus skrev: onsdag 05 juli 2023 22:56
Alla håller tydligen inte med om skribentens slutsats. Enligt ovanstående studie skulle klusterammunition kunna rädda tusentals ukrainska liv.
Självklart är det så. Det är emellertid - och som bekant - inte en uppfattning jag delar. Det finns ett stort antal olika sifferuppgifter ("the figures are hazy") om vilken ytverkan man uppnår med klusterladdningar, splitterladdningar (som M30A AW, Bonus, SMART; Elbits M454 ) och konventionella spränggranater samt granater med klusterladdningar. (DPICM). Främsta anledningen verkar vara att USA har svårt att förse Ukraina med spränggranater i tillräcklig omfattning, inte vapenverkan själv.
Foundation for Defense of Democracies skrev:DPICMs would ease Kyiv’s dangerous shortage of artillery ammunition. This “shell hunger” has already undermined Ukraine’s ability to repulse Russian advances around the eastern city of Bakhmut and may worsen as Western stockpiles continue to dwindle. Unless resolved, this shortage would likely hinder Ukraine’s much-anticipated counteroffensive — in which Washington and its allies have invested billions of dollars — later this spring.
DPICMs offer an untapped source of supply. According to the lawmakers, the United States possesses nearly 3 million DPICM rounds. Some are likely past their shelf life or otherwise unsuitable for Ukraine. But even a few hundred thousand could make a critical difference to Ukrainian forces, who are currently firing around 3,000 to 4,000 artillery shells per day.
Elbits M454-granat är mycket intressant och liknar i vapenverkan HIMARS- missilen M30A1:s alternative warhead:
https://elbitsystems.com/product/m454/
Liksom för BONUS- och SMART-granaterna frigörs stridsladdningen hos M454 ur granathöljet och faller nedåt på ett kontrollerat sätt (för M454 en fallskärm liksom för SMART-granaten, medan BONUS använder aerodynamiska bärplan, eller små vingar om man så vill). Det är ungefär såhär C-DAEM-ammunitionen kommer att fungera, om nu USA kan samla sig till att fasa ut klusterammunitionen. De stater som ratificerat Oslo-konventionen resonerar nog på ungefär samma sätt.
Fast nu var det ju det att banditen Netanyahu inte säljer vapen till Ukraina: Why Won’t Israel Send Arms To Ukraine?.
De kan ju hamna i Iran.
Men - återigen - jag moraliserar inte över Ukrainas ställningstaganden.
PS. Påfallande hökaktigt nummer av The Economist, förresten. De flesta europeiska länder döms ut som Putins nyttiga idioter. Även Sverige får sig en släng av sleven: Vladimir Putin’s useful idiots
Senast redigerad av dr Cassandra Nojdh den torsdag 06 juli 2023 10:17, redigerad totalt 1 gånger.
Enceladus skrev: tisdag 04 juli 2023 20:25 Russian MiG-31 crashed in Kamchatka
Militarnyi skrev:This is not the first accident with the Russian MiG-31 in 2023.
In April, a MiG-31 interceptor from the 98th Separate Mixed Aviation Regiment of the Northern Fleet of the Russian Navy crashed in the Murmansk region.
Also in January, one of the Russian fighter jets caught fire as a result of a compressor stall during a combat mission in Belarus.
Ryssland har förlorat ännu ett stridsflygplan av typen MiG-31 utanför Ukraina. Engelskspråkiga Wikipedia listar ytterligare två olyckshändelser:
Wikipedia skrev:On 8 April 2022, a MiG-31 of the Russian Aerospace Forces crashed in the Leningrad region.[115]
On 2 December 2022, a MiG-31 of the Russian Aerospace Forces crashed during a training flight in the far eastern Primorsky Region.[116]
Är detta en kombination av dåligt underhåll och onormal användning?
Sixth russian MiG-31 Crashed Since 2022, This Time in Kamchatka
Defense Express skrev:As of this article is being written, there is no data whether the two MiG-31 pilots have been found, neither is known about the reasons that led to the accident. Though worth noting, this is the sixth time this type of aircraft was lost in a non-combat situation since early 2022, when russia started actively use MiG-31s in the invasion of Ukraine, if we consider only the publicly announced cases.
October 4th – a MiG-31, probably even the MiG-31K variant capable of carrying Kinzhal missiles, strayed out of the runway of Belbek air base in occupied Crimea and fell from a cliff (see video below).
Once again, only the publicly announced instances, the list doesn't include, for example, the episode that happened in December 2022 when the Belaruski Hajun community reported one more MiG-31K put out of order because its engine caught fire during takeoff.
Således har Ryssland förlorat åtminstone sex flygplan av typen MiG-31. I denna upp­räkning ingår alltså inte januaris obekräftade brandincident i Belarus.
Enceladus skrev: onsdag 24 maj 2023 19:04 Ukrainian air defense uses Patriot systems in ways that surprised the US – expert interview
The New Voice of Ukraine skrev:Accordingly, their abilities are limited only by the number of serviceable MiG-31K aircraft that they can put up in the air simultaneously. It seems that 6 MiG-31K aircraft is their maximum, with 10-12 aircraft available on paper. Reports that a Kinzhal can supposedly be mounted on a Tu-160 or Tu-122M3, fortunately, are just not correct.
Observera även att minst en av förlusterna sägs vara den sällsynta varianten MiG-31K som kan avfyra Kinzhal-missiler. Det finns bara en handfull sådana!
dr Cassandra Nojdh skrev: fredag 16 september 2022 23:22 Populismen är verkligen en outsinlig källa att ösa ur. Egentligen är det här en fråga som i första hand borde hanteras på militär nivå, där de populistiska frestelserna förhoppningsvis inte är lika stora. Om vi utgår från de typer av självgående artilleri som Ukraina redan har - PH2000 (DE), K9/Krab (PL), M109A2/3 (US), Caesar (FR), Zuzana (SK) - och det faktum att Archer egentligen inte tillför någon förmåga som de uppräknade systemen inte har, borde det ligga närmare tillhands att först undersöka om Sverige kan få köpa ytterligare 10-15 pjäser av något av dessa system och donera dem till Ukraina. För varje ytterligare system som tillförs Ukrainas försvarsmakt måste denna ha utbildad pjäspersonal, utbildad underhålls- och reparationspersonal samt tillgång till reservdelar för just det systemet.
T-155 Fırtına: Ukrainian General Staff announced the supply of Turkish self-propelled guns
Militarnyi skrev:Ukraine expects the supply of Turkish T-155 Fırtına tracked self-propelled guns.
The T-155 Fırtına ACS is a localized version of the famous Korean K9 Thunder howitzer manufactured and assembled in Turkey. According to the statements of the Turkish defense industry representatives, they were able to master the production of all the components of the K9, except for the engine.
Än en gång får Ukraina en ny typ av självgående artilleri. Men Erdogan är ju populist - förhoppningsvis en nöjd sådan:
Enceladus skrev: onsdag 05 juli 2023 22:27 Flera källor uppger att intensiva förhandlingar pågår om att godkänna försäljning av amerikanska stridsflygplan till Turkiet. Blir Erdogan äntligen nöjd?
dr Cassandra Nojdh skrev: onsdag 11 januari 2023 10:39
Enceladus skrev: onsdag 11 januari 2023 6:10 USA verkar inte vilja ge Ukraina klustervapen - då kommer den ovan nämnda räddaren i nöden.
Ja, banditen Erdogan vet verkligen på vilken sida av brödet han har oljan, och kan konsten att spela flotta viktor - när det passar hans syften.
Biden-administrationen kovänder - snart får Ukraina klusterammunition. Då återstår frågan: Är ammunitionen till eldrörsartilleri eller Himars?
Ukraine's new Bohdana 155mm howitzers able to fire guided munition to target Russian troops
Army Recognition skrev:According to an article published by the Jerusalem Post on July 4, 2023, the 1st battery, attached to the 57th Motorized Infantry Brigade of the Ukrainian Armed Forces, employs the latest version of the local-made 2S22 Bohdana self-propelled howitzers, known as Bohdana 2.0, to target Russian troops near the village of Druzhkivka in the central Donbas region. Following the successful testing of this upgraded version, this means Ukraine now has the capability to launch American M982 Excalibur 155mm precision-guided shells from the howitzer.
Tydligen har Ukraina börjat använda sitt egentillverkade självgående artilleri 2S22 Bohdana. Ännu ett system som Ukrainas försvarsmakt måste hantera!
Enceladus skrev: torsdag 06 juli 2023 3:08
Ja, man upphör aldrig att förvånas. Det citat som inleder ovan avsåg Sveriges agerande, inte Turkiets.
viewtopic.php?p=409198#p409198
Jag jämför (än så länge) inte Sveriges regering med Turkiet. Beträffande Turkiets "vapenhjälp" till Ukraina har det påståtts mycket, en del har materialiserats, annat har varit rena rykten.
Erdogan är f.ö. inte en populist, han är en bandit och diktator. En sådan blir aldrig nöjd, speciellt om vederbörande har praktiserat i Istanbuls basarer. Vad Erdogan vill uppnå är en gåta, och det är så han vill ha det.
Intensiva förhandlingar? Turkey Snubs US Pressure on F-16s as Biden Meets Swedish Premier
Tja, vem vet?
Senast redigerad av dr Cassandra Nojdh den torsdag 06 juli 2023 10:13, redigerad totalt 1 gånger.
Enceladus skrev: torsdag 06 juli 2023 4:54 Ukraine's new Bohdana 155mm howitzers able to fire guided munition to target Russian troops
Det kan inte röra sig om särskilt många pjäser. Ukraina har egentligen det militärtekniska kunnande som krävs för att ombeväpna sin försvarsmakt och göra sig kvitt det gamla sovjetiska skräpet, men saknar i det stora hela produktionskapaciteten - av lättbegripliga skäl.
Enceladus skrev: torsdag 06 juli 2023 4:54 Biden-administrationen kovänder - snart får Ukraina klusterammunition. Då återstår frågan: Är ammunitionen till eldrörsartilleri eller Himars?
Extremt underliga referenser - rena twitter-rykten m.a.o.
Några missiler är inte aktuella, eftersom de är skrotade, se vidare: viewtopic.php?p=414482#p414482
M26-raketen har inte tillverkats på över 20 år, och skrotas nu i en automatiserad process: The Army Is Using Robots to Dismantle Hazardous Rockets
Det är alltså bara granaterna M483A1 och M864 som kan vara aktuella. Hur många sådana som faktiskt finns operativa i USA:s förråd är oklart. USA har skrotat mycket klusterammunition: http://www.the-monitor.org/en-gb/report ... olicy.aspx
innan Trump satte stopp för detta. Siffror mellan 300.000 och 3 miljoner har nämnts, t.ex. hos de hör hökarna: https://www.fdd.org/analysis/2023/03/28 ... o-ukraine/
PÅ tal om hökar. Såhär kan man tydligen beskriva Oslo-konventionen
Carlos Mucha skrev:That we’re not shipping UA cluster munitions is batshit crazy, they are (per US Army) 6 to 15 X more efficient than high explosive shells but most of our European allies signed a unilateral disarmament CM treaty & the Biden WH doesn’t want to make them look stupid
"Batshit" var en intressant språklig innovation, t.o.m. för att komma från en högervriden amerikan.
Senast redigerad av dr Cassandra Nojdh den torsdag 06 juli 2023 9:46, redigerad totalt 1 gånger.
Men den här polska höken är ännu värre, eftersom vederbörande anser att alla Nato-länder bör säga upp Oslo-konventionen och börja tillverka klusterammunition igen:
Break the Taboo: Cluster Munitions Needed by Ukraine, Poland, and NATO
Det är ganska vanligt i högerkretsar att beskriva folkrättsliga konventioner som "tabu", dvs. religiösa vanföreställningar. Men Polen verkar ju vara ett bra land, mycket vapen och lite demokrati. I Warszawa har Trump goda vänner: Trump ally Poland conflicted over Biden win
dr Cassandra Nojdh skrev: måndag 19 juni 2023 20:18
Enceladus skrev: måndag 19 juni 2023 12:21 France summons allies in challenge to German-led air defence plan
Financial Times skrev:Russia’s invasion of Ukraine and its heavy use of munitions and missiles to attack from the skies were a wake-up call that Europe could no longer neglect its air defences. “We have a lot of catching up to do in Europe”, Scholz said in an August speech setting out his vision for air defence.
But key countries such as France, Italy and Poland have remained on the sidelines, showing the challenges of overcoming national industrial interests even as military budgets are ramping up across Europe. Paris in particular was caught off guard by Sky Shield’s announcement and postponed a Franco-German summit in part to signal its pique.
Although countries in Sky Shield each make their own procurement choices, Germany has said it plans to buy Iris-T missiles from homegrown manufacturer Diehl group for medium-range protection, the Patriot from US-based Raytheon Technologies for long range, and the Arrow 3 from Israel for very long range. The German parliament last week signed off on the first purchases: a set of six Iris-T units for €900mn and the first tranche of funds in a $4.3bn deal for the Arrow 3 missiles.
In Paris, the exclusion of the Franco-Italian SAMP-T missile defence system made by MBDA and Thales, which serves a similar range as the US-made Patriot, has proven a sore point.
Ukrainakriget blev verkligen ett missat tillfälle för SAMP/T. Amerikanska Patriot hann stjäla rampljuset innan Frankrike och Italien lyckades skicka sitt.
Här beskrivs konflikten mellan Frankrike och Tyskland om luftförsvaret: France and Germany Are Beefing Over Air Defense Batteries
Med underrubriken
Classic European dispute
Såhär nöjd såg Macron ut när han berättade att Ukraina nu opererar ett SAMP/T-batteri. Sedan hände det ju en del annat på hemmaplan...............
Låst
